jakebot
  1. I have been on here and other sites and have gotten a stupid amount of conflicting info. I have the 1996 OB with the 2.5 with120,000 on it and I think I need: Timing Belt Timing Belt Tensioner Water Pump Crankshaft Seal Cam Shafts seals (I assume there's 2 or 4 not sure if this is SOHC or DOHC) Idler Pulleys I don't wonder if throwing a new t-stat and a seal or gasket if I need it wouldn't be a bad idea I also assume at this time replacing the coolant would be a good idea as it needs to be drained anyway. There may be more that i'm unaware of as well. Does anybody have a kit they recommend that has all the stuff you SHOULD do while at it that's high quality parts? It doesn't have to be OEM just not junk parts. Thanks in advance.
