Mangot2
  1. I have a 99 Legacy Outback that I just acquired and one of the several things I’m working on is the washer system … neither the front or rear worked when I got it so checked and verified fuses and then bench tested the pumps. The front was ok, but the rear failed. I cleared the lines for the front, cleaned the nozzles and now it’s working ok. I blew air through the rear line and had fluid shooting up the back glass so looked like a new pump should fix that. I installed a new pump and still inop but can hear the pump running ok. I disconnected the line and blew air through it again but now nothing comes out. I tried to blow air back through the nozzle but the anti-syphen valve prevents that … anyone else been through tracing rear washer hose blockages? Alldata doesn’t show the routing or connections … Thanks in advance!
  2. I have a 99 Legacy Outback that I just acquired and one of the several things I’m working on is the washer system … neither the front or rear worked when I got it so checked and verified fuses and then bench tested the pumps. The front was ok, but the rear failed. I cleared the lines for the front, cleaned the nozzles and now it’s working ok. I blew air through the rear line and had fluid shooting up the back glass so looked like a new pump should fix that. I installed a new pump and still inop but can hear the pump running ok. I disconnected the line and blew air through it again but now nothing comes out. I tried to blow air back through the nozzle but the anti-syphen valve prevents that … anyone else been through tracing rear washer hose blockages? Alldata doesn’t show the routing or connections … Thanks in advance!
  3. I am new to the Subaru ownership arena, primarily a Jeep XJ guy, but have been around them throughout my automotive career. Thanks for having me!
