Wyatt3.14
  1. I'm wondering what I should do to upgrade my suspension I found an old thread from 2012, but the links to the write up would not work
  2. I'm pretty sure this is issued because the car is running rich and I have a check engine light to how can i find one
  3. I put premium in and it didn’t go away I Took off the gasket and found it it was exploded I’m going to make my own gasket and hopefully it will fix it here’s an image of the blown up gasket i’m also gonna grind down the y pipe with a wire brush to make it as flat as possible https://drive.google.com/file/d/1oX6pjdbuj2hrfZfkyQg6y5xw176ECNt2
  4. I tried looking for holes in the exhaust and I just replaced the Y pipe to header gasket here’s a video if anybody can tell what the sound is https://drive.google.com/file/d/1z3RonlfegrhahdQQ7wqLB_02kvI8GRiz/view?usp=drivesdk
  5. sounds like an exhaust leak but I cannot get it to go away replaced y-pipe gasket any recommendations
  6. I have one more question what tires would you recommend on r13
  7. Thanks so much I’ll give it a try what website would you recommend to buy parts from
  8. I’m not sure if the stress I’ve been serviced and has 220,000k I would prefer flatter cornering I probably should get new struts too I don’t know if there was coils or anything that could make it stiffer Only time it’s heavily loaded is in the winter when it’s filled with ski gear
  9. Any recommendations just need it to handle better
