Lazer
Posts posted by Lazer
Or use an clutch alignment tool.. Usually comes with the clutch kit.
Also you can try shaking the crap out of the engine while applying pressure towards the tranmission. usualy works for me.
+1
All you need for an Ej alternator to work is a wire from acc on the ignition to the alternator. if you don't do this the alternator won't charge.
At first I just connected the wire directly to the battery. But when then engine is not running it will draw some current from the battery this way.
Also in addition to poor grounding it could be a bad alternator. You can fix the humming noise by installing a capacitor parallel with your stereo power.
Yes it will fit.. no problem there.
As I remember there should be a wire comming from the alternator that needs switched 12v for the alternator to alternate
Sorry Don't remember the colour could be black or yellow or something
If not connected to a switched 12v source but directly to the battery you can hear a low noice from the alternator.
Its a hack job on the ordinary impreza setup.
I had a top mount intercooler. Now it's there for the air cleaner. oh yeah and for looks
Just thought I should ad this here as well.
Nothing too fancy.
looks like you have a bit of rust there huh
So why do you want to have a ej18 turbo.. Why don't run a ej20??
Pretty sweet setup. Have you had a chance to run it at the strip yet?
Not realy as there are few "strips" here in Norway. But I have been running it at the street and I'm very satisfied with it. Did run it against a Honda s2000 and the xt was faster
When hitting the trail let air out of your tires!!
When i go wheeling I typicaly run about 8-10 psi
That will improve your gear ratio and give you bether grip.
I want to see some pics of this EJ20 XT.
Well you can se some picture of it here http://subaruxt.com/forum/viewtopic.php?t=7143&highlight=
Thanks for your help
Yeah well I've more than once gone for a "cheaper" option and then bought the expensive quality part because the cheep one was rubbish.
I have an subaru xt turbo with an forester turbo transmission and an ej20g legacy engine.
Lately I've had problems with my clutch. This clutch is an cheep kit type rated for 300hp I bought out of e-bay:
When letting out the clutch it is far to brutal.
It was nice and smooth when I first installed it.
What could cause this?
The clutch is a push type cable opperated one and I have to say that it does take some abuse from my suped up ej20g.
Is there an difference in the clutch itself if it's push/pull type?
I don't get this.. What kind of clutch should I look for??
Thanks
Martin
Board Member: Lazer
Engine: EJ20g legacy turbo with vf34 turbo
Chassis:1985 Xt turbo
Tranny:forrester turbo with lsd rear
Other: full legacy/forrester turbo drivetrain with legacy turbo brakes up front. Big front mounted intercooler, autronic ecu, etc.
Sorry I just had to comment about the first video.
I belive than when using one winch in the rear and one in the front as he is using I could have done than with a subaru as well.
But yeah you are right sammy kick subaru. Infact it's a sammy that have the worlds offroad altitude record.
I definatly need the template to my ej20g xt
NICE car
Well, I've owned two of them, and I'm no hairdresser. And Jared drives one right now as a daily driver. I thought Jared was a Soldier in the Marine Corps, but I guess he's a hairdresser now.
edit* I checked your "photos" tab, and nothing. Can't really say you have anything to show as for your off roading expertise or knowledge. Search around a bit, you'll see the two of us have wheeled quite a few Soobs in quite a few places. My sig at another forum is: "I've off roaded more Soobs than anyone." And I have.
You're not making friends here pal.
I'm sorry for having offended you.
But I guess You've taken this too personaly. I just said what I think about subaru's offroad. You are probably right about that I don't have that much experience with offroading at all.
And about the hairdresser's car.. I was trying to make a joke. (The hair dresser statement is actualy a quote from wheeler dealers on Discovery channel) I was asking for a reaction and I did get it After all I have stated that I love subaru's on and off road. (this is a subaru forum isn't it?)
Btw. I'm not much of a video/picture guy but you can watch a few videos on youtube taken with my cellphone (search for subybrat) Also my post count is only in the 50's So I'm realy not that active on this forum. Anyway I'll leave this post alone.
Thanks
Martin
SubaruXT.com down?
in Meet n' Greet. Your USMB Welcome Center
Posted
+1 Has been down for a few days now.
