Everything posted by Boringchuck
2000 Legacy/Outback driveshaft for AT - unavailable except for more than $600!?
Boringchuck replied to Boringchuck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUPDATE #2: I *FINALLY* found one on Ebay from a very well-rated seller for $330 Here's the LINK
Boringchuck replied to Boringchuck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUPDATE: I called the driveline shop and they said that since Subaru stakes the u-joints (and don't use c-clips to retain the bearing cups) they can't be rebuilt, nor can the carrier bearing (most likely). Sigh . . .
Boringchuck replied to Boringchuck's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXImdew - DUH! Of course! I'll check that out right away! THANKS!!
WOW! I've been trying ot find a replacement driveshaft for my 2000 Legacy/Outback with automatic transmission. EVERYBODY seems to have them for a manual tranny, but not automatic or for a zillion other years - but the lists jump over year 2000! The only one I can find is Dorman at $603. YIKES! Any ideas other than a used one? I 'suppose' I could rebuild my existing one, but I don't know if the u-joints are staked and non-repairable (it's outside, I'm inside and lazy right now) Thanks!
Vibration at 25-35mph and light load and at highway speeds - getting worse!
2000 Outback 130k new to me. It didn't have vibration when I boguht it 500 miles ago, now it does. It feels like judder from 25-35, but there's also vibration at highway speeds.Also, it lightly 'clunks' (that I can feel more than hear) when the gas pedal is let off of then put back on. The highway vibration is getting worse. I added the magic goo (Lubegard 19610 Instant Shudder Fix) to the tranny 100 miles ago - no improvement in the vibration from 25-35 mph. I'm thinking it may be the driveshaft carrier bearing or its rubber mount (but 130k is kinda low for that I'd think). My question is: how to diagnose that without pulling the driveshaft. I had the car up and crawled under and pushed up and down on the driveshaft and it moved rather easily - I don't know if the rubber mount should alllow easy movement or if it should be stiffer, it just seemed rather soft to me. The tranny mount just got replaced by a competent mcechanic. Any see-through-brick-walls folk out ther who can diagnose from a distance? : -) Thanks!
2000 Legacy L - uses 205/60r15 tires, can I go to 205/70r15 without rubbing?
I have the opportunity to get some nicer rims (not steelies with crappy platic covers like I have now) and very good Bridgestone tires for cheap. B U T . . . They are 205/70r15, not the 205/60r15 that are on it now (and are the OEM spec). Will I get rubbing? I know my speedo will be a bit whacky, but that's OK with me. The offsets on the rim are 55mm which is fine, so that's OK. Here's the specs differences: (main issue: the 205/70r15 is 41mm or 1.61" larger in diameter)
