bajablasted06
Everything posted by bajablasted06
  1. Finally solved it for anyone wondering it wasn't actually oil burning like we thought at all it somehow is getting brake fluid sucked in from the brake booster which I didn't even know was possible
  2. With pcv disconeted still burns oil i let it run for several minutes incase of residual the cylinder walls were honed when when the rings were put in and the rings were gapped but it seemed like it only worked for 300 miles before starting to smoke bad I think Ill either tear it down and do rings again and measure everything to make sure its in speck or grab a junkyard short block to through in thanks you all for your ideas
  3. It smokes a fair bit out of the oil filler but i didn't notice any blow by maybe a tiny bit at idle but goes away however the smoke goes up with rpm
  4. Its naturaly aspirated no turbo but I did check the pcv system and replace all parts of it intake seams to be dry
  5. Looking for help my 06 baja sport is drinking oil and smoking bad I took the engine out did the rings didn't fix it then did the valve seals still to no avail thanks for any help
