Rear Wheel Bearing Job Question
02subyL replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXhere's an update on my project. Finally got the bolt out and removed the knuckle. I will be replacing the two bushings as well as that bolt.
02subyL replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI found this related thread: http://www.ultimatesubaru.org/forum/showthread.php?t=6571 I think at this point I will be replacing that bolt (it's twisting 1/4 turn at one end and seized at the other) and the two bushings too.
02subyL replied to hohieu's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe knuckle itself is not threaded, but you've probably figured that out now that the bolt spins. I've got the same thing going on right now with my '97 Impreza. Any success?
smaller snow tire size
02subyL replied to 02subyL's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthanks!
I found a deal on some nokian nrw's for $19 each here. They only have one size: 185/55R15. My question is, would that be too small for my 97 impreza? (stock size 195/60r15) I've read that you can go smaller for winter tires, but how small is too small?
clogged egr line
has anybody here had success cleaning the carbon out of the metal line that goes under the throttle cable? i've tried soaking it with solvent, drilling down both ends, but can't clean past the bends. '97 impreza 2.2l
Rough idle - sometimes it stalls...
02subyL replied to Stormy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI've got what seems to be a similar problem with my 02 legacy wagon (automatic) I changed the fuel filter, air filter, plugs, wires, and right now its at a garage, but the mechanic there ran the diagnostics but no sucess on what the problem is. I'm looked at Muse's thread and am wondering if reprogramming the ECM solved the problem. I'll post if we find anything new.
Am I going nuts? Hesitating, cold, or going bad?
02subyL replied to muse's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have an '02 Legacy with similar issues. Did the reprogramming fix it?
02subyL
