STRANGELUCK65
Posts posted by STRANGELUCK65
i work at a body shop and always have adjust the window hieght when i replace a door.first remove the door panel and then peel back the upper part of the vapor barrier, at the top of both window tracks are the stops.put your window up to the correct height,open and close the door to be sure you have it where you want it. slightly bump the window down using the power window switch, then loosen the stops and push/nudge them down and retighten the stops. open and close the door again. cycle the window up and down a few times, open and close the door again. if you are satisfied with the fit to the weatherseal reinstall door panel. doing this is not hard, just pay attention to what you are doing and don't rush it.My 2002 Impreza has a movable stop that controls how far the window goes up. It attahces to one of the tracks (I believe the rear one) with a 10mm nut and you can move it up and down about an inch. Maybe your car has something similar. -
i thought the same thing when i was told. but sure enough it works.Again i ask why are people using this to fix torquebind. Torque bind is in the clutch pack of the automatic transmission. Limited slip diff fluid is gear oil, not tranny fluid. They are seperate animals. If i caught anyone putting something meant for a differential in my auto tranny fluid they would be in in a pile of trouble form me.nipper
hello *** is this thing on?anybody therestill in need of wiring diagrams -
still in need of wiring diagramsSo if I told you I was a mechanic that always got As in English would you not like me anymore?Figure out that PM thing and get ahold of me. I'll get you the manuals you need.
*hint - PM instructions are in the post above mine;)
here is a tip from 2 senior master subaru mechanics that i will pass on to you guys.use ford motorcraft additive friction modifier,it costs less than $5.on the back of the bottle has printed "FORD INTERNAL REF. NO. 135454" i have used this myself and it does work.Thanks for the replies. Did a search and found a lot of very useful posts on torque bind. I always appreciate the help I get at this forum. Top notch! -
wet sand spoiler toget rid of the bad paint.be sure next time BASF paint is used.i do paint and bodywork for a living-trust me.if you have any more questions pm me.Take it back and tell them to do it right this time. Remove all of the old paint and scuff up the spoiler so new paint can stick. Then use a paint adhesion promoter before priming and then before putting down color and clear. -
i do heavy collision bodywork.the hid units are from broken headlite assemblies.i strip them down to just the igniter pack and bulb socket.from there, they can be retrofitted to almost anything.cut a hole in the back of whatever headlite housing you choose,epoxy bond the bulb socket area from the hid assembly.find a suitable place to mount the igniter pack-and thats about it.KEEP IN MIND you will loose your hi beam.if you have fog lites it shouldn't be a problem.what do you do for work??? you a one of the many europe manufacturer techs??? or Japanese tech??? or a tire guy whose really smart at taking things?? thatll be me soon enough! -
i've got a box of used hid set ups at work.if you or someone you know is good at creative reengineering, i'll send you a set for a bottle of whiskey to be named latter.just pm me.
yes. i still need both,the other guy didn't send it.now that i know what a "pm"is-how do i access it.please overlook any misspellings,its a curse of being a good mechanic.zzzI have it as well.. Can be had from my FTP. Let me know if you still need it. -
whats a pm, and how do i use it.i'm not dumb-just smart in other areas:headbang:I have PDF files for the complete 02 wrx, engine suspension tranny etc, with wiring diagrams. It is complete and I'll send them to you if you want. Just PM me with your email, they are large and will DL most effectively with a highspeed internet connection. They have pics and diagrams tooCk
hell yeah-i'll take what i can get.email is strangeluck65@verizon.net. still need diagrams for 98 outback
no cutting ,slicing or dicing nessesary. everything bolted right in. i went from a 2.5 dohc w/auto to a 2.0 wrx w/5spd.the only problem i'm having is finding good wiring diagrams.i've done avionics in the past-so i'm not stupid when it comes to chasing sparks.i can do it without diagrams,but it will be a whole lot easier with them.i had enuf foresight to remove the comeplete harness from the wrx.any help in this matter will be apreciated.
a '01 legacy turbo hood will fit,or any hood of the same bodystyle.the only thing that may be diferent is the grille.if you or someone you know is good at bodywork-i have a baja scoop assembly that can be fit to anything.i do bodywork/heavy collision,so i know it can be done.soon i'll be fitting an '04 sti scoop to a '00 rs hood for a '96 sport wagon.bodywork is easy provided you don't overthink it.if you need any advice email me at strangeluck65@aol.com .
all week i fix trainwrecks for the local subaru dealer (mastro subaru-tampa).base your desision on structural demensions.measure from rear fender bolt to forward fender bolt on the opposite side,this is called an x-out. is the damage above the frame rails? is one or both rails bent?if so you could sub out the frame straightening to a bodyshop and finish it yourself.contrary to popular belief,mig welders are simple to use - if i can teach a big tittied blonde girlfriend to use one it aint that hard.if you choose to attemt to fix it and need demensions,let me know.like i said,this is what i do for a living.the way people drive here in tampa-i make a damn good living.
Howdy,i'm Shawn.i've Been A Subaru Heavy Collision Specialist (bodyman) In Tampa Since The Mid 80's.the Cars I Fix Are The Ones That Look As Though They've Been Hit By A Train-(industry Term Is Trainwrecks).so From Time To Time I Have Left Over Or Repairable Parts To Trade.presently I Have A Sti Hood W/hail Damage That Falls Into "spoils Of War" Catagory.see In My Field Of Expertese,we Get To Keep Stuff That Would Normally Be Thrown Away.so I"ll Be Posting Things W/very Accurate Discriptions That Are Reuseable,w/options Of "as Is"or Fixed.you Would Be Amazed On How Little Damage Constitutes Replacement To The Insurance Companies.please Disreguard/don't Make Fun Of Any Misspellings-afterall,i'm A Mechanic.
02 wrx complete drivetrain in 98 outback
in Subaru Retrofitting
Posted
well, i finally tracked down the diagrams i needed. wish me luck - all i got is strangeluck
