88glwagaroo
  1. sorry for taking so long to reply----i just finished installing another engine in the 86 because for some reason sometimes it would miss at idle then it would smooth out or again would miss throughout the range of tach---had to add quart of coolant evervy two weeks but good compression readings on all fours cylinders---i replaced everything (i mean everything and it still sputtered) --- so now i can at least drive it till i get time to convert it the new motor has 264000 and runs perfecto except for the nagging oil leaks for which they our famous for --- by the way i saw a post with the saying if it aint broke don't fix it-well it ain't broke no more but i will break it again --- just wait
  2. i have everything including the dual range 5 spd..car is already a standard with ea82 carb. also would like to install spfi if i can
  3. thats why paper sludge came out of my oil pan
  4. pop one on that is the xact same size as the other 3 and your problem will be solved
