scttysctt
Everything posted by scttysctt
  1. Thanks guys I'm going to try to finish the job tonight.
  2. Hey does anyone have any tips on getting the Crank Pully off of a 96 EJ22? I'm trying to do a timing belt and waterpump replacement and the pully won't budge. The local Subaru dealer told me to hold on to the pully and have someone turn the bolt with a ratchet, but that didn't even come close. I have a neighbors puller, but can't get it into position to do any good. Is this bolt reverse threaded? Any tips would be awesome. Thanks.
  3. I had the same problem in my 96 Legacy, it got worse and eventually overheated without cooling back down. I replaced my thermostat, but it did fix the problem, and now I am getting ready to replace the water pump. Good luck.
  4. I didn't use a Subaru Thermostat, but as I said it appears to be working. Gnuman, Olnick or anyone else got a theory? I kind of doubt it's the HG because the car runs like a champ otherwise and I don't see any major leaks or too much condensation in the exhaust. Any ideas will be warmly accepted. :-)
  5. Thanks Olnick, it's not good news, but it's news. Yeah the coolant fluid is mostly discolored with maybe a little grit in it, and I'm not sure about the oil, because it's time to change it anyway. If it's the gasket it might be time to get a new Subaru instead. Thanks again.
  6. Where is the Thermostat located then? The problem is the car will run for about 3 or 4 minutes until it gets too hot and then I have to shut her down until the engine cools down again. The radiator has plenty of coolant so I know it isn't that and I have had people telling me to replace the thermostat and someone else the Coolant Temp censor. What do you think? I already bought a thermostat so I might as well replace that if I can get to it. Thanks guys, this board is awesome!
  7. Thanks Gnuman and Olnick. I'll try to do it tonight. I may be stupid but is there any difference between a Coolant Temp Censor and a Thermostat? I've been hearing both terms from people and assumed they are the same part.
  8. I replaced my thermostat, but my car still seems to be heating up and then not being able to cool itself. Any ideas? The new thermostat is working very well, as I went to remove it altogethor and warm water was trickling through it, so I left it in. Could it be a water pump that needs replaced? It's a salvage car but has driven fine for a year and a half, and the CEL has been on every day since I got it. In this heat (So Cal) I can't even drive 5 miles to get a computer on it to see what the errors might be. Maybe if I drive it in the middle of the night. To Kraggen.
