I'm trying to drain the coolant in a 2005 Outback Legacy, the owner's manual isn't specific.
1. How does the radiator drain? I unscrewed one of the 2 lower nipples with a 19mm hex, nothing came out. Is this normal?
2. How to remove the plastic guards underneath the radiator corners? There are some round plastic pins holding the guards in place. Are these reusable 2-piece push pins like with interior panels, or do they break when you pop them out?
3. How does the overflow bottle drain? I didn't see a screw on the bottom. Does it have to come out? Does it come off the fan shroud or does the shroud have to come out? Looks like a rubik's cube of plastic tabs lock the bottle to the shroud. I removed the top screw but it didn't seem to do anything. What am i missing?
thanks for any help
