front lower control arm rear bushings - question
Yes I have replaced many of these, they are around 70 dollars if I remember correct, or you can replace the whole control arm for around 35 dollars from wrecking yard.
They are two way you can tell when they are bad, one way is the grease will start coming out of them, the other way if you turn around on a two lane hiway you will hear it pop.
The one problem I have found when replacing the bushing the arm will try to swing around and the bolt will try to crossthread so dont use impact wrench to install it.
