October 24, 200916 yr hi . i have an k-reg legacy turbo and a s-reg outback and want to put the turbo engine into the out back is this possible.
October 27, 200916 yr I don't know a lot about the swap. I sent you this way from the outback forum. I do know that the turbo engines typically are not preferred for swaps. Sorry I could not be of more help.
October 27, 200916 yr hi . i have an k-reg legacy turbo and a s-reg outback and want to put the turbo engine into the out back is this possible.question is hard to take seriously without any more info. you can install a jet engine in a Justy if you want or a 350 into a Suburu. anything is possible with enough time, money, skills, or beer and a sawzall! so i don't even know where to start with an answer. let's try this: it'll bolt up but not be plug and play.
