November 15, 200916 yr I have a 2004 subaru legacy and for some reason I am not to sure where the pcv valve is? Can anyone help me on this?
November 16, 200916 yr The above picture is for the 2001 and earlier. Starting in 2002, the PCV valve was moved to the OTHER end of that hose down in the engine block rear. On the 2002 and newer, that picture is just an orifice where the upper end of the PCV valve attached to the throttle body. Follow that hose down and you will find yours. Also note, it IS a different valve and part number from the one that was mounted on the throttle body as shown.
November 16, 200916 yr Sorry about the wrong answer, at least the OP should be able to find the PCV now with your instructions and the pic. Edited November 16, 200916 yr by valvestem
