Leaking R&P-need advice.
Once again, I am seeking the infinite wisdom & advice of the USMB membership.
My rack & pinion is leaking ('04 Legacy) and probably ought to be replaced. I have a Subaru CD-ROM shop manual which states that the steering wheel and u-joint need to come out. Is there any way around that? I can see the u-joint, at least on the R&P end, but the whole thing including the steering wheel & airbag?
I don't really mind the work. I did the head gaskets and resealed the oil pan recently. I know there are some folks out there that have done that and may not have pulled the steering wheel & airbag, etc.
I gave the Lucas oil leak stuff a try and so far it was a waste of money, so don't go there. It's "that smell" I am trying to fix, as well as the leak down onto the exhaust Y-pipe.
THANX
No you don't need to mess with the steering wheel.
Just unbolt the clamps on both ends of the u-joint where it connects to the rack.
4 bolts hold the rack in place.
Undo the tierods, and the hydraulic lines and it comes right out. Might need to remove the swaybar to clear.
Thanks. I assume the front exhaust pipe needs to come out too, or not? I may get to tackle this if the weather fairs up this week.
pretty sure yes the exhaust needs to come down. a 2004 leaking p/s rack - that's odd.
Well, I knew the head gaskets were bad (leaking). I fixed that. I knew I had another leak and thought it was either the rear seal and vent plate, so I pulled the motor & resealed that. Then I resealed the oil pan and the only oil level that was going down was the steering fluid. It may be just a hose but I may need to dye check it for sure before I go yanking it out.
