will 05 16in wheels/tires fit on 90 Legacy Sedan LS AWD ?
Have a chance to pick up a set of 16" 2005/2006 Subaru Legacy silver wheels. Tires are stock size...will these fit on my 90 Legacy LS Sedan AWD ??
Tire Rack says they are both 5/100 ...but not sure if there will be any interference issues....Thanks Tommy
Well, I have a '93 Legacy LS Wagon that came stock with 185/70R14. When I bought it used last year, it had been switched to 16x6.5" alloy wheels that were taken off a '97-'04 Legacy. It now has 205/55R16 tires and everything works fine, with plenty of clearance. The only problem is the speedo/odometer now reads about 2.8% too low because of the larger tires. I know this isn't quite your setup, but but it may be close enough to be helpful. Cheers!
The wheels will fit fine. The tires you woud have to test fit for clearance. They may be too tall or wide and rub the struts.
I had 16" WRX wheels on my 91 Legacy with stock 205/55 size tires and had no trouble at all. Noticed a huge difference in handling.
Thanx Soob xperts...Im going to pick them up tonite..They have the original Bridgestones on them with 80 / tread..like new wheels too.200 bux! :banana:
Durania:- Those wheels really look good on your Legacy too
Thanx again guys...Tommy...be posting pics of my 90 soon...
