T'subaru Posted January 20, 2010 Share Posted January 20, 2010 Check these guys out. http://www.usaradiator.com/SUBARU--LOYALE--1990.html Part number 1269 used in most l series, my 90 loyale, 89 rx, 93 sedan and 86 gl Link to comment Share on other sites More sharing options...
Frank B Posted January 21, 2010 Share Posted January 21, 2010 did you buy one of these? When i bought one for my 92 Loyale, I kept getting a one row copper/brass one instead of a two row. Turns out that the two row was replaced by the one row copper brass unit. The one row aluminum replacement with plastic tanks is still available, and that's what I ended up buying. http://www.ultimatesubaru.org/forum/showthread.php?t=90764&highlight=radiator Link to comment Share on other sites More sharing options...
T'subaru Posted January 22, 2010 Author Share Posted January 22, 2010 did you buy one of these? When i bought one for my 92 Loyale, I kept getting a one row copper/brass one instead of a two row. Turns out that the two row was replaced by the one row copper brass unit. The one row aluminum replacement with plastic tanks is still available, and that's what I ended up buying. http://www.ultimatesubaru.org/forum/showthread.php?t=90764&highlight=radiator Yea, local parts seller here can supply new single row, plastic tanks for 93.00. Twin core is my preference as all my subs are ea82t powered. who did you buy from? Another vendor is performance radiator. I spoke with them recently and closest stock was in New Mexico. Link to comment Share on other sites More sharing options...
Frank B Posted January 23, 2010 Share Posted January 23, 2010 Performance radiator wasn't one of the companies I bought them from, but every one I talked to, or found online, or the local parts stores, at the time had the same brand/suppliers and ALL said they could get the two row because all of the info they had never changed when the two row was replaced by the one row copper/brass unit. If you can get them to put one in thier hands, and maybe send you an actual pic before you buy it, you'll know for sure. Link to comment Share on other sites More sharing options...
