January 21, 201016 yr first off its a EA82T... I'm getting a weird cold start issue, but only when its below about 40 degrees or so... It starts up fine, idles fine, but once I start driving and the temp gauge starts to rise, it will start bucking like it isn't getting enough fuel. It doesn't do it with the clutch disengaged, it only happens when the engine is loaded. It will go away after the engine warms up a bit more, and I don't have a problem after that. Any ideas? Could it be the clutch slipping when because it is cold? or maybe the IAC? I tried searching the forum to no avail. Thanks in advance........
January 22, 201016 yr I would change the fuel filter and check the CTS connector for corrosion. Ignition system check after that. Edited January 22, 201016 yr by naru
January 22, 201016 yr Author Fuel filter was just changed about 1500 miles ago, and it happened before that.... also, it doesn't matter if its under boost or not, and it doesn't throw any codes when it does it... Could the spark plugs be causing it?
