February 18, 201016 yr I may need to swap out the engine in my 2000 Impreza. It has an EJ222 with no EGR. Will a late modelEJ22 work without wiring or exhaust mods? What about issues with EGR?
February 18, 201016 yr EGR won't matter in your case, if you get an EJ22 with EGR you just plug the EGR hole, i've done it before. you'll retain your intake manifold and bolt it to the new engine. plugging an EGR hole is much simpler than making one, that's why it's harder to go the other way. you'll need a Phase II EJ22 and it should be a directly plug and play swap. so 1999+ EJ22.
