Newb help, ea82T
Can someone take pity on my soul and snap a labeled picture of the ea82t oil and coolant lines for the turbo, my Chilton's is not helping for this.
TIA
gloyale posted this in something unrelated
"there is an oil line bolted to the rear of the head, low in the corner.(hard line, banjo bolt style. Don't lose the 2 copper crush washers)
A larger oil return tube beneath the turbo.(5/16 or 3/4 trans cooler hose works well. Diesel Truck repair shop would stock)
And also a coolant return hose (1/2 inch heater hose) that snakes under said plate then clamps to a pipe that bolts to the underside of the head. There is a small 10mm bolt holdin that pipe to the head as well, near the exhaust port.
Coolant supply hose on the top is obvious."
so, a pic would still be ok, I'm dealing with mess from the PO
