88 GL D/R Wagon - Another EJ Swap
Trevor
That really bites the big 'un, but if you look at your car's value as a culmination of the parts you've put into it....they can be swapped over to another cheap wagon. That mindset is what finally made me decide to seriously off-road it. The body isn't worth near as much as what's under the hood!!!
  • 3 months later...
  • Replies 82
  • Created
  • Last Reply
Top Posters In This Topic
Made some progress here. It has taken a while, but I found a really clean 91 Loyale with a dead motor and sourced all the parts to repair my EJ. Motor in the bay with the dual range and the lift is in.
  • 1 month later...
Project has been on hold for a while. But I have made a ton of progress in the last week.
Did not want wiring hanging above my feet on this build so I put my ECU in a box in the spare tire well. I picked the components up at lowes for about $30. It should keep water out.
Everything is good to go except radiator fans, which are "Out for Delivery" according to UPS :)
Can't wait to do some off roading!!
  • 9 months later...
