May 12, 201015 yr I stripped out my dash and unplugged a bank of 4 relays(?) and im not sure if I got them plugged back in right. The relays have stayed in the holder, so their order should be right. I just need to know which wire goes to which relay.
May 12, 201015 yr They are for the the following: Heater blower Rear defrost Headlight Left Headlight Right They all use the same relay and the relay will only plug in one way. As long as each connector has a working relay, your fine. Actually that's one of the ways I test relays in these cars. Just switch em round to test wether the circuit has a problem or the relay.
May 12, 201015 yr Author I have deleted the heater, and both headlights work so I guess that is not why my turn signals stopped working. Might have left something unplugged.
May 12, 201015 yr Author when I deleted the heater I took the vacuum canister thing out from the passenger side strut tower. Is there anything else that feeds off of its vacuum supply? It looks like the push button 4wd works off of it but Im swapping in a D/R 5mt.
July 29, 201015 yr I have deleted the heater, and both hid headlights work so I guess that is not why my turn signals stopped working. Might have left something unplugged. It could be exactly that. Did you check everything was plugged?
