5 speed d/r questions
I tried searching but couldn't find quite exactly what I'm looking for but I'm going to look at a flywheel, driveline, and 5 spd d/r out of an 86 gl tomorrow to hopefully swap into my 84 wagon and was wondering if there was anything I can do to check the tranny out before wasting my time. The motor is out of the car at the moment so other than making sure it spins, anything else I can do?
drain the fluid and check for any chunks, grit or silver shiny stuff. might want to take a pan if you think the guy doesn't want gear oil all over the ground. :eek:
Hi This is Jerry, i make a 5 speed kit for your 84 wagon and i can let you know all of the ins and out about installing the 5 speed. Call me 1-509-952-2855 before you buy parts that you don't need. Thanks Jerry
Draining the fluid is a good Idea, I think I can handle that. Jerry, thanks for the help, Ill give you a call when I get outta class today.
  • 2 weeks later...
