May 30, 201015 yr My driver's door window would not go up very far this morning. It made a crunching noise. I had to get out of the car and pull the window up while pulling on the window switch. I would appreciate any help.
May 31, 201015 yr You need to pull the door panel and have a look. The motor is held on with 3 bolts. Once the panel is off, peel back the plastic and see what is going on.
May 31, 201015 yr Your window regulator is shot. Napa usually carries decent ones, but the best ones are had at the dealer.
