Turn signal switch
Remove the 2 plastic surrounding pieces that cover the steering column. At the bottom of the t/s stalk is two phillips screws, take them out and unplug. Easy as that :)
Love how Subarus are easy to work on!
Isn't it great? The secret of all that, is the flasher is inside the switch too :) Knowing that will save you a lot of time if you ever need to look for it to diagnose.
