July 12, 201015 yr Hi everyone it's been a while since I posted here. I just took a 250 mile trip in my loyale and now it idles very high. Seems to run ok, but idles at 3000 rpm. I am going to try and fix it tomorrow. Just wondering what could cause this? Vaccum Leak? Isn't there an idle selonoid on these? What about a slipped timing belt? Has anyone had this problem, and if so what did you do to fix it? Thanks Jon
July 12, 201015 yr Author Well I just pulled the air control valve. I have to run to town for some carb cleaner and a new air filter. Will post back with my results of the air control valve cleaning. Jon
July 12, 201015 yr Author Hi Ivan The idle was steady. I could burp the throttle and it would momentarily drop, but would go right back up to about 3000 RPM. I just got the air control valve cleaned and reinstalled, new air filter, and general throttlebody cleanout. Problem solved Jon
July 14, 201015 yr What exactly do you mean by "general throttle body cleanout"? I had the same issue a while ago, except not such high idle. And cleaning the iacv fixed it mostly, but sometimes it will still idle a little high for a bit.
