1st Subie is a brat..
Will its actualy my Moms car and i'm the mechanic,,but I feel like I need one also..any ways here is my question.
what is the third lite called? and wher can I find a switch?
also anyone have any leads on a good price for the topper holders? thanks for your time and help.
its an 82 brat then well the lamp in the grille is called the center lamp or passing lamp and is for (cough,cough) off road use only the switch is a push pull type and is below the steering wheel on the left side just below the head light switch
the topper hold downs are j bolt that hook to the bed tie down handles you can use just about any j bolt as long as its a 1/4 inch or smaller and about 6 inches long the universal battery j bolts that napa sells work great if they are threaded most of the way down
sorry, i ment to say replacement switch..
and the struts to hold up the lift gate on the topper..found some on ebay..but we all know how that goes sometimes.
I should have been more clear..
thanks for chiming in.
