hose
on my 94 legacy turbo there is a little (U) shaped hose under the alternator that goes to intake and motor It is apparently only on the turbo as I don't see it on a 91 non turbo. Does any one know what I'm talking about and has
anyone ever found one. I have no subie dealers closer than a hundred miles and they don't even want to talk to you without a part number.
Try emailing the folks at Subarugenuineparts.com. I hear they're good at hunting down parts and are very helpful. And I'm pretty sure you'll get a discount by mentioning the USMB.
is it the little 1/4 thick hose for the map sensor assembly, or are you talking the other one?
i am pretty familiar with ej22t's
or might this just be the larger breather tubes connection where it "t's" behing the alternator, that plastic T fitting (like glass after 100k miles) connects breathers from left and right valve covers, and also is part of the pcv system and if that part fractures your car will run like pooo.
to try to explane it better it is about 3/4" diam opening. it will lay in palm of hand. It runs from bottom of intake manifold to a nipple just below it. Hence the tight 180 or U shaped bend.
