...Q's about ECM code and No Dash or Running Lights
1983 brat with hitachi and A/T
1st :-\
I need help with a ECM code 22...... vehicle speed sensor
where is it ? how do in check it ? or replace it?
2nd:-\
i have no dash lights or running lights.....
fuze #12 blows when installed
Where do i start to look to find short???
Any help Would be Greatly Appreciated
NO one has ideas?
or do you..like me...... just do not know!!
grrr:-\
To get you started,my 83 owners manual shows fuse 12 feeding the ignition coil and fuel pump.
Suggest you get a circuit breaker to sub for the fuse for testing purposes.
Tailights are on fuse 11.Look for power here.
VSS is on the back of the speedo w/the cable.
Take the following w/a grain of salt as it is based on an 84 FSM,not 83.
Likely the same,but,who knows?
For starters,locate the 4 pin pink and 17 pin yellow check connectors under the left side of the dash.
Put your voltmeter between the yellow/red wire in the 4 pin and the black/red wire at one end of the 17 pin.
You want to see more than 2.0 volts.
If less,unplug the instrument panel and try again.
