aaronxs400 Posted January 5, 2011 Share Posted January 5, 2011 http://www.coneeng.com/pdf/Flanges%20and%20Gaskets%20PDF.pdf Look at their 2 bolt flanges the universal 2 bolt flange FL2B-163 has a 1 5/8 hole with a 2.95 bolt hole center distance. There is about .20" to the edge of the flange from the end of the hole and about .45" from the inside of the hole to the edge of the center hole. im gonna order 2 and see if i can make them work. will keep you updated. Quote Link to comment Share on other sites More sharing options...
adema2626 Posted August 16, 2011 Share Posted August 16, 2011 So did this work for you and how much did it run you? I know this is an older post, but this is exactly what I need right now before WCSS haha. Quote Link to comment Share on other sites More sharing options...
