January 10, 201115 yr I have finally located everything for my 4wd/MT swap. Are the torsion tubes the same, or interchangable, between both models? Thanks! I some how posted this in the wrong place...can this be moved or deleted? Edited January 10, 201115 yr by aaronxs400
January 10, 201115 yr They swap out the same one way or the other. The physical difference between the 2 would be the diff mount in the center.
January 10, 201115 yr so either will work? thanks I don't believe the 2wd version would have the diff mount bracket....
January 11, 201115 yr I don't believe the 2wd version would have the diff mount bracket.... This is the physical difference between the 2. If you had only a 2wd oart available, you can fab a diff mount easily enough, at least if you knew what was supposed to be there or had one to compare to.
