February 13, 201115 yr I have a 85 GL-10. I have a broken marker light/turn signal on the drivers side. I do not have a spare parts car and I cannot find this item at any of my local junk yards. Will another suby model car have the same light to bolt up? It is almost time for inspection! Is there a online parts house that has older model lights for suby's?
February 13, 201115 yr any 85/86 gl/gl-10 wagon coupe, sedn will be the same style, any 88-89 will fit the same as well, different orange lens, though, and 90-94 loyales will also fit. You have 10 years of car in any configuration that will fit the same.
February 16, 201115 yr Author Need more help! I have called all the local junk yards here in Virginia. Nobody has any suby parts. Is there a aftermarket website that would have lights/signals/accessories for older subys?? Any suggestions would be appreciated.
February 19, 201115 yr Aftermarket is virtually non-existent for these cars. Pretty much limited to normal consumables and repair parts. Wrecking yards and forum members are your best bet for body parts. Or you could go to the dealer$hip, and they MIGHT be able to get a corner light for you.
February 19, 201115 yr I have an 89 parts car that might have good lights. Haven't really checked. I would check later today if you want tho. The front driver side signal right?
February 20, 201115 yr I have a 85 GL-10. I have a broken marker light/turn signal on the drivers side. I do not have a spare parts car and I cannot find this item at any of my local junk yards. Will another suby model car have the same light to bolt up? It is almost time for inspection! Is there a online parts house that has older model lights for suby's? hi , i have that, pm sent
February 21, 201115 yr Author Thanks for all the info. Got the pm from ruparts- deal in progress:banana: thanks!
