2004 gasket kit installed in 2006 impreza.
I noticed that the 10104AA070XX ENG GSKT SET is not a part I found listed for my 06 impreza wagon.
It is a 2004 part as far as I can make out.
http://www.dealerdirectparts.com/2004-SUBARU-IMPREZA-OUTBACK-Engine-Cylinde-p/subaru-5748308-imp-out-4.htm
But according to opposed forces
http://opposedforces.com/parts/impre...llustration_3/
I should have 10105AB020 GASKET & SEAL KIT
https://content.subarunet.com/snet/_...Pg%2072-74.pdf
Below is a list of the parts installed last year.
What is the difference between the recommended 10105AB020 GASKET & SEAL KIT and the 10104AA070XX ENG GSKT SET I got ?
Bellow is the list of parts.
11039AB890 HEAD ASSY-CYL RH
13202AA371 VALVE-EXH
13207AA120 SEAL-INT VALVE
13211AA110 SEAL-EXH VALVE
806732150 0ILSEAL-32X45X8
21236AA010 GSKT-THERMO
44616AA030 GASKET -EXHAUST
11063AB310 HEAD ASSY -CYL LH
13294AA070 GSKT-ROCKER COVER
11044AA633 GSKT-CYL HEAD
13211AA 110 SEAL-EXH VALVE
10966AA030 GSKT -SPARK PL PIP
902370010 FLANGE NUT (WAS 9 2
Technician: 12
install new timing belt
REPLACE TIMING BELT NO LABOUR
13028AA231 BEL T-TIMING
