February 15, 201115 yr I noticed that the 10104AA070XX ENG GSKT SET is not a part I found listed for my 06 impreza wagon. It is a 2004 part as far as I can make out. http://www.dealerdirectparts.com/2004-SUBARU-IMPREZA-OUTBACK-Engine-Cylinde-p/subaru-5748308-imp-out-4.htm But according to opposed forces http://opposedforces.com/parts/impre...llustration_3/ I should have 10105AB020 GASKET & SEAL KIT https://content.subarunet.com/snet/_...Pg%2072-74.pdf Below is a list of the parts installed last year. What is the difference between the recommended 10105AB020 GASKET & SEAL KIT and the 10104AA070XX ENG GSKT SET I got ? Bellow is the list of parts. 11039AB890 HEAD ASSY-CYL RH 13202AA371 VALVE-EXH 13207AA120 SEAL-INT VALVE 13211AA110 SEAL-EXH VALVE 806732150 0ILSEAL-32X45X8 10104AA070XX ENG GSKT SET 21236AA010 GSKT-THERMO 44616AA030 GASKET -EXHAUST 11063AB310 HEAD ASSY -CYL LH 13294AA070 GSKT-ROCKER COVER 11044AA633 GSKT-CYL HEAD 13207AA120 SEAL-INT VALVE 13211AA 110 SEAL-EXH VALVE 10966AA030 GSKT -SPARK PL PIP 902370010 FLANGE NUT (WAS 9 2 Technician: 12 install new timing belt REPLACE TIMING BELT NO LABOUR 13028AA231 BEL T-TIMING
