February 26, 201115 yr My daughter's 86 Brat GL runs out of gas when it has only used about 4 gallons. The float sinks, so the gauge is not much help. The tank has no obvious dents. Any ideas>
February 28, 201115 yr Pickup up tube in tank could also be clogged. I've had a problem with gas delivery, and had to hook up a hose so I could blow back into tank. Remember if you do this to remove the gas cap.
February 28, 201115 yr Author Thanks. I am going to change the filter and drop the tank to look at the pick-up. The pump will be next.
