March 12, 201115 yr The cruise worked before the engine swap,fuse is good.I see a vacum nipple that comes out of the firewall it is on the drivers side of center I think this may be the problem.if so where do I conect the hose to when I get a new one. The sunroof is slightly out of position after I manually adjusted it. The passenger side arm that operates it is disconnected or broken end therefore dose not operate is it a big job to fix one of these or relativly simple? I forgot I need info on a failed emmisions guy ave me a code I think its a Subsru code p1440 Edited March 12, 201115 yr by coach9
March 12, 201115 yr Author Fixed the cruise,iwas a VAC line over on the passenger wheel well!:banana:
