bigger side rear mirror
I pull an Aliner trailer with the 2006 Forester. The side rear view mirrors are just a bit too short to have a good rear view. I tried the clip on’s, but they shake like crazy and shift away in a short time. I need something that I can bolt on firmly, that means of course to remove the old mirrors. Are there any bolt on mirrors for that? I don’t want those huge things that you often see on RVs.
Thanks
how about a spot mirror or a wide angle stick-on? if you stand alongside the car, you should see the driver's face in the mirror when adjusted properly. The spot mirror will help you see the white fog line and the road immediately next to the vehicle, while the rest of the mirror is looking straight behind you.
Thanks Fox, the thing is the mirror has to extend outwards a bit. When I look in the mirror now I see the left front corner of the trailer, and I ‘d like to see whats further back behind the corner. Looking around the corner, that would be great.
