Legback Posted March 24, 2011 Share Posted March 24, 2011 I've been studying the archives and I already replaced a rotting fill tube. There is a black box back there behind the right rear wheel with hoses and there is what looks to be a solenoid. I tested-- it had 25.9 ohms resistance. The power supply had 11.9 volts. But the metal cover rotted off and now there's just a plastic piece and instead of an alert on my scantool it's fulltime red PO440. Can someone tell me which solenoid this is? My research points to vent solenoid but I can't find diagrams anywhere!! Thanks:-\ Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 24, 2011 Share Posted March 24, 2011 There are a few solenoids back there. It's either the canister vent control valve or the pressure control valve. Is it the one right next to the canister or is it the one further forward? Quote Link to comment Share on other sites More sharing options...
Legback Posted March 24, 2011 Author Share Posted March 24, 2011 Do they both have a lead going to them? I think it's the smaller one toward to the wheel well. The hoses form an L as they come off of it and there's a white power connector.?? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 24, 2011 Share Posted March 24, 2011 After looking closer, there are 3 valves possibly back there. One that you probably can't see because it appears to be over top of the canister. Which also appears to be called a vent valve. possibly this is one of he changes on the later models. What year car is this again? http://www.subarupartsforyou.com/cp_partdetail.php?partid=12556 The vent valve that I think you're looking at has fairly large hoses, maybe 5/16" Id. One loops out of the leading (forward) port makes two quick 90° turns and ends. The other comes out of the top port and loops to a hard line which runs to another hose that goes to a filter above the canister. http://www.subarupartsforyou.com/cp_partdetail.php?partid=12552 The pressure control solenoid valve is the one located forward of the fuel tank next to where the rear brake lines come out of the floor pan. Quote Link to comment Share on other sites More sharing options...
Legback Posted March 24, 2011 Author Share Posted March 24, 2011 Mine is a 98 leg out Lim WAG. 2.5 --Canister valve ventilator looks like it??? will trace the lines better today. Thank you!! Quote Link to comment Share on other sites More sharing options...
Legback Posted March 24, 2011 Author Share Posted March 24, 2011 Does that filter ever need changing?? Like when your filler necks been sucking fine dirt in for who knows how long.! Quote Link to comment Share on other sites More sharing options...
Legback Posted March 24, 2011 Author Share Posted March 24, 2011 Ordered Canister ventilator valve. Any reason not to bypass that brief section of solid pipe and run one length of rubber tube from the CVValve to that filter looking thing? Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 24, 2011 Share Posted March 24, 2011 I imagine eventually the filter might get plugged up with dirt. I haven't ever seen a thread about anybody needing one though. I'd just leave the metal line in place unless it's rusted out. That type of stuff is generally in place to minimize stress on certain components, or guide hoses/wiring around obstacles that might rub or cut. Quote Link to comment Share on other sites More sharing options...
Legback Posted March 24, 2011 Author Share Posted March 24, 2011 Was messing with the old valve still in the car and it broke in half. Now I've got a PO446 to go with my po440. And it's ductaped. Does this stuff effedt how the car runs or is it emissions related only or what? There is no pressure built up when I release the gas cap. That section of solid pipe is very rusty and prolly not airtight. That filterlike item is rusty too. It's all suspect really. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 25, 2011 Share Posted March 25, 2011 P0446 Subaru Evaporative Emission System Vent Control Circuit Guess you know which one it is now. The evap system only collects fuel vapor from the gas tank and routes it into the engine to be burned off, rather than venting it to the atmosphere. The engine will run the same regardless, but your car might smell like you just went to the gas station all the time. Quote Link to comment Share on other sites More sharing options...
Legback Posted April 8, 2011 Author Share Posted April 8, 2011 Update== I did replace that vent solenoid and about 100 miles later, all of my alert lights on my scantool stopped blinking and I've had a green light ever since. No evap, cat, or O2 alerts! Quote Link to comment Share on other sites More sharing options...
