June 1, 201114 yr BIW is the same, so you need: - transmission/linkage - prop shaft - rear suspension - fuel tank
June 1, 201114 yr ive done it the other way, but i have done plenty on gl's. what about a 4wd xt drveline in a 2wd gl? that is what i am driving
June 1, 201114 yr Anyone ever done a FWD to 4WD conversion on a 1986 XT? its doable but unless the body is MINT than its too much effort, especially when 4wd Xts can be found fairly easily..
