June 22, 201114 yr I know the OBW's from 96 on have raised suspensions over a base legacy, Was wondering if the case is the same for Impreza's? Would a 95 "Outback" trim Impreza have shorter struts/springs vs a 96 and up OBS?
June 22, 201114 yr 95: The ground clearance was 6.3", the same as the L Sport Wagon. I can't find info on the 96 but in 97 it was raised to 6.4"
June 22, 201114 yr Author So 1/10th of an inch? I would say there is no real difference. That could be due to different tire/wheel sizes even. Thanks
