Seeking Independent Suby Mech near 02171
Hi folks! Haven't posted here in ages. I just moved to Quincy, Massachusetts, and I'm looking for a trustworthy indy mechanic to do a timing belt change on my 2002 Legacy GT (SOHC EJ25). Any recommendations?
Thanks!
Myles
Thanks! I'll give them a call.
Myles
Anything in particular you need? I am a driveway mechanic on-call.
  • Timing belt change
  • TB Tensioner
  • Water pump
  • Accessory drive belts
  • Coolant change
  • Brake and clutch fluid change
Thanks again for the referral.
Myles
  • TB Tensioner
  • Water pump
  • Coolant change
Myles
You'll get the best service at Chicken and Shakes. It's a total grease shop with no fancy waiting room. If you bring your own parts it might make things to a bit faster. Call them to make an appointment, but they can totally do it. (They did mine.) I stay away from timing belt and water pump jobs simply because it's too easy to screw them up, so when I had mine done I brought it to Chicken and Shakes and they did a great job.
Did you do the water pump, tensioner, and cam seals along with the belt?
Myles
Myles
I did the cam seals last summer, but I had them replace ALL the pulleys and tensioners when they did the timing belt and water pump. I got them all from Subaru, which cost a lot of money. The aftermarket kits are great and inexpensive, but the Subaru OE parts are slightly higher quality.
