July 13, 201114 yr How do i check the codes? This is in my 1987 gl hatchback. Thanks Edited July 13, 201114 yr by thebr0wn0ne
July 13, 201114 yr There is a small hole in the ECU where a LED can be seen. You connect the black plugs together and turn the key to ON and then count the pluses. Long flashes are 10's units and short flashes are single units. Five pulses means a normal code.
July 13, 201114 yr Author Thanks a lot coug. I'll give it a shot and get back to you.Don't you just love it when you're first car has problems
