August 21, 201114 yr well i have a 86 xt with the ea82 N/A that is gettin tired i have another ea82t lined up. but i heard you could swap it with a ej22, what all would i need to do this swap. or should i just stay with the ea82 set up, any ideas thanks
August 21, 201114 yr Don't bother with the EA82T, if you do a search here you'll find hundreds of threads about its problems. The EJ22 swap is much better and produces more power. Do a search for this too, theres several people here running ej22's in there EA82 bodys using both the stock EJ22 EFI system and also some with weber carbs. SJR makes adapter plates to bolt an EJ right onto an EA82 tranny along with modified flywheels. Always search first:grin: Welcome to the USMB!
August 25, 201114 yr go to Numbchux Conversions EA2EJ manual its a great start! even if you are doing an obdii swap, the basics are there, but the obdii is slightly different wiring etc. i did it, and i've never attempted anything this drastic before! just take your time and READ
