August 22, 201114 yr my girlfriends car is Subaru Outback 96' EJ25 ive been try starting became fire up but somehow shut down with during (temp oil light flashing)? thats mean need repair new oil or what?
August 23, 201114 yr Sure it's the Oil Temp and and not the AT Temp? AT Temp flashes 16 times after you start the car when there's a transmission fault.
August 24, 201114 yr Author exactly... i've been trying driving for short but RPM was high became lower to shut down... ive been turn over again but shut down... whats its? :-\ Sure it's the Oil Temp and and not the AT Temp? AT Temp flashes 16 times after you start the car when there's a transmission fault.
August 24, 201114 yr my girlfriends car is Subaru Outback 96' EJ25 ive been try starting became fire up but somehow shut down with during (temp oil light flashing)? thats mean need repair new oil or what? exactly... i've been trying driving for short but RPM was high became lower to shut down... ive been turn over again but shut down... whats its? :-\ Umm, what? Can you clarify what you are asking here? Your questions and responses are really confusing Is your AT Temp light flashing 16 times at startup? What are the car's symptoms?
August 25, 201114 yr Author actually.. i was replace new fuel filter and somehow my wagon wont running as last.. i did waiting for 5 min running but still no good. when i was start it like a 10 sec later shut down...with oil temp flash. Umm, what? Can you clarify what you are asking here? Your questions and responses are really confusing Is your AT Temp light flashing 16 times at startup? What are the car's symptoms?
August 26, 201114 yr These are two seperate problems. The Flashing AT Temp light has nothing to do with it not starting! Did you cross the fuel lines?
August 26, 201114 yr Author i did put the right of the fuel filters hose (in & out) i try running but it just shut down...with during "oil temp" flash. what u mean cross the fuel lines?? These are two seperate problems. The Flashing AT Temp light has nothing to do with it not starting! Did you cross the fuel lines?
