'98 OBW stalling/ cutting out/flat spot
I decided to start a new thread; the old one seemed to fizzle out and had an embarrassing misspelling in the subject header! I'd really appreciate suggestions- I'm getting desperate to fix this.
'98 OBW 5-speed, 216K, 2.2 swapped about 5 years ago.
It has started doing a variety of things-
Sometimes bucks/ stalls on takeoff. Once in a great while stalls at idle, hot or cold. Sometimes loses power (all cylinders dead) while accelerating, then power comes back on. Sometimes light "trailer hitching" trace miss when cruising at a constant speed.
Sometimes it will run perfectly for an entire 45 minute trip.
No cel is on, no stored codes.
I put a scan gauge II on it- coolant temp reads out normal, TPS seems OK, it goes to closed loop OK, no out of range or erratic readings that I notice. It's hard to get a reading while it's doing it though- the scan gauge updates pretty slowly.
I tapped on the MAF. Plugged and unplugged all the connectors on the engine harness, wiggled wires with the engine on.
Any thoughts? Thanks in advance!
Nathan
  • 1 month later...
