vacuum line question 98 forester 2.5 dohc
my problem is upon ressembly I have more hoses than nipples for the small vacuum lines, one is the device located right next to the IAC valve, it is black, takes a two connector plug, fastened with a single 8 mm bolt into the intake casting, (it is a solenoid), one line loops back and down a few inches to a metal line under the intake runners, the other line has a longer hose that I cannot figure out where it goes. There is also a device mounted on the passenger side inner fender that has a line which is different than other lines, sort of a grey or green color with looks like an inline filter, I have no clue on that either, again any help much appreciated....thanks
