November 20, 201114 yr I have a legacy with auto belts and they are messing up can I replce with manual type? Thanks
November 21, 201114 yr I assume you have a '90-'94 model Legacy? Actually you're in the right place--apparently Canadian models came with manual belts those years. You will need the Canadian trim pieces to do the job right. Check the "Similar Threads" at the bottom of your post or try a search. Good luck.
