November 27, 201114 yr HELP How do you replace the bottom coolant hose on the bottom side turbo? I have a leak on the rubber coolant hose, I can see the end by the wheel well but not the other end because it is under the turbo unit. Any ideas would help. Thanks, Larry:Flame:
November 28, 201114 yr your gonna have to pull the turbo off. i blew that same hose far from home once. had to do it on the side of the road.
November 30, 201114 yr Author Well I found out that you can replace the lower turbo cooling hose without removing the turbo. Dealer quoted me 4 hours labor to remove & replace the hose. This was just an estiment. The wife had a plan to do the job and it took 3 hours with out removing the turbo. BTW the hose was not at fault it was a bad hose clamp. I saved 400.00 bucks by their estiment. Thanks.
November 30, 201114 yr That four hours sounds like the labor for the turbo is involved. Suppose the technician can do it without pullng the turbo. I have done it. So what will happen is you will be paying 4 hours labor for about a half hour's work.
November 30, 201114 yr Author Yougot it Miles. 400.00 for replacing a hose. Woman came into service desk for a recall repair . The service rep told her she was do for 80000 mile service. She ask how much; 419.00 a sudden smell came over the room of ************. She said no and left saying just do the recall!
