ergo Posted December 21, 2011 Share Posted December 21, 2011 I've got a couple of quarts each of Redline 5w/40 and Eneos 5w/40. I'd like to use both together in the next oil change on my 2000 Legacy. What are your opinions on mixing them? They're both high end synthetics. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted December 21, 2011 Share Posted December 21, 2011 Not really supposed to do that, each has their own type of detergents, and they don't usually take to mixing well. They can fight each other. The oil part would be okay, it's the additives and what they are made up of that don't mix. Quote Link to comment Share on other sites More sharing options...
danbennett2u Posted December 22, 2011 Share Posted December 22, 2011 I have never heard of any negative effects of mixing different brands of oils personally. I would say you are probably ok unless you plan on racing or trying to run extended intervals with the oil. Quote Link to comment Share on other sites More sharing options...
the3rsss Posted December 22, 2011 Share Posted December 22, 2011 Do it! Don't give it a second thought. The anti-wear agents used in motor oil are basically minerals. Boron, magnesium, etc. No ill effects mixing different minerals. But basically they all use the same ingredients. Look at the petroleum quality institute website. Most of the ingredients are the same. Quote Link to comment Share on other sites More sharing options...
