91 legacy 2.2l knock sensor
Getting code 22 which calls out knock sensor. Where is this located? 1991 legacy 2.2liter non-turbo.:confused:
the knock sensor is located on the drivers side of the engine block directly below the throttle lever on the intake manifold. use a 12mm socket and a long extension to remove the bolt.
